mini wireless pinhole camera
Discussion in 'Wireless & RF Design' started by jeff6000, Jan 25, 2011.
  1. jeff6000
    Jan 25, 2011
    i got one of those cheep wireless video cams from ebay its 900mhz-1200mhz output power 200mw i was wondering if thare is aney way 2 build a transmitter amp to boost its range im puting it on an rc car
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Messing with transmitters without FCC approval can be a problem for you. While you are unlikely to get caught unless you cause interference, if you do, the fines can be pretty high.
    Secondly, the FAA (and presumably other agencies) are looking at implementing very tight restrictions on unmanned, remotely controlled vehicles and models. If you want a scary update, read the current Model Aviation from the AMA.
    With that backdrop, I think a hobbyist attempt to increase range and possibly make an out of sight remote vehicle is very ill advised.
    John
  3. jeff6000
    Jan 25, 2011
    well i was just planing on runing it around my pard woods behind my house im not woried about the fcc stuf i just wan some one 2 help me out
  4. Kermit2
    Feb 5, 2010
    3,852
    968
    Line of Sight. LOS.
    The more clutter between you and the transmitter the weaker and more scattered the signal becomes. A time honored method of increasing range is to elevate the antenna.
  5. jeff6000
    Jan 25, 2011
    i need some one 2 give me a diagram on how 2 build a power amp
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    You CAN NOT increase the power without crossing the rules of the FCC.
    More power for the camera would be illegal.
    As told change the antenna position to have a wider view.
    Bertus
  8. jeff6000
    Jan 25, 2011
    im not woried about fcc because its 4 educational perposes only
  9. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Doesn't make it legal. Seems your keyboard is busted.
  10. PackratKing
    Jul 13, 2008
    850
    216
    If you have the equipment and ability, "cheep" video cameras are not tuned too tightly, so if you can get the xmtr and your rcvr tuned to spot-on frequency, you may -- as in might get a wee bit better performance.
    Aside from that, it's best to take the advice of the the guys here, and not lock horns with the FCC..You will lose.
    Give them attitude, you will lose bigtime, 'cuz they don't play games....they can impound and / or destroy your "toys"....and fines are hefty.
  11. radiohead
    May 28, 2009
    474
    31
    The PN918 is a good RF amplifier with a wide frequency range. The MPF-901/NTE64 is an RF amp in the DC to 2 GHz range. You can feed a signal into the MAR-3+ drop-in amp to boost your signal to 400mA.
    Since the circuit in your camera is already tuned, adding an RF amp would likely de-tune the circuit, so you probably wouldn't be able to receive the signal without a fair amount of alignment to get it right.
    Read http://www.fcc.gov/oet/info/rules/ carefully before you modify commercial off the shelf equipment to make it operate outside the scope of its intended function.
