Mini LED panel Voltmeter connections
Discussion in 'The Projects Forum' started by Max12345, Oct 19, 2013.
  1. Max12345
    Aug 27, 2013
    63
    Greetings
    The first link is the one I have purchased. The second link just has more photos of the same item, but with Red LEDs.
    http://www.ebay.com/itm/DC-0V-99-9V-3-wire-Mini-Blue-LED-Panel-Meter-Digital-Voltmeter-/121195040045
    http://www.ebay.com/itm/Red-LED-Panel-Meter-Mini-Digital-Voltmeter-DC-0V-To-99-9V-AT66-US17-NEW-CHEAP-/261306423512?pt=LH_DefaultDomain_0&hash=item3cd71398d8
    I have purchased a mini 0V-99.9V DC Blue LED panel mount voltmeter which I have not received yet. I wish to use it on my power supply.
    I have mailed the seller (in China) for a spec sheet, but I am not holding my breath.
    Has anybody used this meter before?
    Do you know or have the specs?
    I would like to know whether it uses the same power supply that it measures or whether it should have its own isolated power supply. Is there a schematic available to do this if required?
    Max
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    it says it needs its own power supply
    "Power supply range: 4V-30V"
    It has 3 wires..
    1 ground ground
    1 power supply+ wire
    1 measurement voltage wire
  3. Metalmann
    Dec 8, 2012
    700
    223
    Those little meters, are cheap and very accurate.
    Max12345 likes this.
  4. Max12345
    Aug 27, 2013
    63
    So it's not a completely isolated separate power supply for the meter, as it will share a common ground with the actual power supply?
    Does this mean I should or can tap the meter's supply off the actual power supply? I'm unsure as to how to do a dual supply. Can you point me to a link please?
    Max
  5. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Yep, they share grounds.
    The meter needs 4 volts to run itself, so if your P/S can adjust to zero you can't connect the power and sense wires, is will not work below the 4 volts
    BUT... if you have access to the full supply you may well have a good point to tap, like the cap bank itself.
    For a single supply you put:
    +meter power to +P/S cap bank
    -meter power to +P/S return
    meter sense to +P/S output
    For a dual supply you put:
    (+ side the same)
    +meter power to -P/S return
    -meter power to -P/S cap bank
    meter sense to -P/S output
  6. Max12345
    Aug 27, 2013
    63
    Hi ErnieM
    Like this? As shown in the attachment? Is this OK?
    Max
  7. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Ahh, sorry I had assumed you were doing a +/- supply, not just a +
    Yes, what you drew looks correct.
    Since your transformer secondaries are separated, you can join them back together to make each one either a positive or a negative voltage (with respect to some common or ground).
  8. Max12345
    Aug 27, 2013
    63
    Hi ErnieM
    I have to wait 6 weeks for the meter, so I don't want anything bad to happen to it, so just to be sure of the whole circuit, I posted it as an attachment for your perusal.
    Thanks so much
    Max
  9. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Yes that looks like a good way to connect everything.
