Some years ago, I was working on building a MHD generator. I had taken 5 grade 5 ceramic block magnets and two 1 inch wide 8 inch long 1/8th of an inch thick construction steel bars and made a magnetic assembly. I took a very high grade dielectric epoxy and glued all of the north poles of the 5 magnets to one bar. It was very difficult because all of the magnets were in opposition. Block magnets are magnetized through the thickness, and these are those cheap 0.75 x 1.5 x 0.25 block magnets you can buy at Radio Shack. But, with the permeability of the construction steel, which is very high, the strength of the magnetic field is enough to drag a refrigerator around.
At the time I was working on this MHD generator, one of my roommates stuck this thing onto the back of the microwave oven. I noticed that my coffee was taking twice as long to get hot enough to drink. I had used that microwave every day, and suddenly it's warming my coffee like a magic bake oven or just a lightbulb. Then I looked for my magnetic assembly and found it stuck to the back of the microwave. I actually re-lived the same week 5 times because, I touched that thing when the microwave was running. My timeline, if represented by a line drawn by a pencile that starts the day I was born and leads to the present was acting like a transmission line. Superluminal waves have been observed in waveguides when the waveguide is too small for the frequency injected. Typically, all you notice is that you've lost energy from the magnetron. But, this is all reproducable and observable.
This is a duplicate of a Penning Trap, the field inside of magnetron or a homopolar motor. The reason the arc rotates is all the same as to why the magnetron works as a resonant cavity and why the magnets are there, as well as forces that cause the rotation of a homopolar magnet motor. The magnetron's resonant cavity is duplicated here but the situation is well enough controlled that you can observe the reversal of the plasma's rotation.
Rotating Plasmas 4
With a magnetron, it shows up as a sudden decrease in the output frequency, and disturbing the Penning Trap's magnetic field with an external magnetic field can cause the rotational reveral effect. After that 5 weeks out of one situation I went through, I tore that microwave appart and put it back together to figure out how it literally had me re-living that past week 5 times. All I noticed is that it was one of the few microwave ovens built that actually had a waveguide built into it instead of just dumping the magnetron's energy directly into the cooking area.
There was a 90 degree bend in the waveguide so that the magntron was level with the back panel and the height of the waveguide. So, the top of the waveguide was level with the magnetron both of with made contact with the metal cover. I could see that the magnetic assembly was aligned with one of the walls of the waveguide, and it extended past the first magnet on the magnetron but the not the second. Those are just basically two speaker magnets just like in the glass chamber in the video. The difference is that you can't see through a magetron to know what's going on inside.
In the studies that were done using waveguides that were to small it appears that the microwaves travel backwards through the waveguide until they escape. I know that sounds wrong. But, it's like a wave on water travel at a 90 degree viewing angle of the mirror as the wave moves directly away from the mirror. That is the way the microwaves leave the waveguide that is too small.
IN the video you can see that the velocity of the rotation in one direction is much faster than in the opossite. An electron cloud is a plasma, even though you don't think of vacuum tubes or magnetrons as plasma device. But, the raw truth is that they are using and function with charged plasmas not neutral plasmas and an electron cloud is a plasma. So, what happens in the plasma chamber can happen in a magntron. But, if the direction of the rotation of the electron reverses, it will not spin as fast, hence the drop in frequency of the output of the magnetron due to the interruption caused by an external magnetic field outside of the penning trap.
The whole reason that it worked, is that the permanent magnets were coupling to the superluminal energy in the waveguide. One side of the steel was parallel and in line with the waveguide outer wall, the other was more toward the center. The ceramic and the dielectric epoxy made a long magnetized capactor out of two bars of metal. The RF skin was superluminal and followed my timeline like my time line were a transmission line. It actually clocked backwards in time. As my body absorbed the energy, when I touched is is like a picture of my brain with every dendrite, the microwave energy is absorbed more by objects in the present. That modulated space passes an RF energy hologram that guides the growth of your neuron's dendrites and you literally wake up a week before you done anything you remember for that week. It's like a inverted superluminal MRI, and instead of a computer drawing out how much energy was absorbed where, you just absorb the energy, and that absorbtion literally guides dendrite growth, uploading all of your memories of this week to the beginning of it.
If you have the frequency counters and stuff to do this right, I suggest it.
Rotating Plasmas 4
