Mims electronics learning lab
Discussion in 'General Electronics Chat' started by grumm, Aug 19, 2011.
  1. grumm
    Apr 28, 2011
    9
    Hello, I just got the Forest Mims Electronics Learning Lab sold by Radio Shack. I've built the first circuit and it works, but I don't understand why, so I have uploaded a web page with a picture and some questions in hopes that someone here can clarify things for me. I'm sure it's very simple stuff for everybody here, so thanks in advance for any help. I hope it's correct procedure to use my own web space instead of taking up room on the allaboutcircuits server -
    http://members.upc.ie/marilyn.mcconnell/firstCircuit.html
    Gerard
  2. MrChips
    Oct 2, 2009
    12,635
    3,454
    I think you are way over your head here. Take one step at a time. No, one toe in the water first. You'll have to begin with how basic circuits work, R and C, followed by diodes and transistors. There are just too many sites on the net to list here. But don't give up. The journey will be well worth it.
  3. Barnaby Walters
    Member
    Mar 2, 2011
    103
    I agree with MrChips, you'll benefit hugely from slowing down and understanding basics like the difference between voltage and current before trying to understand the functioning of a 555 timer circuit. Vol 1 of the book on this website will be a good read for you (I'm assuming you haven't already read it).
    Once you've genned up a bit, a visual demo of what's happening in the 555 will make everything a bit clearer: Visual Demo link. The Doctronics page about 555s is also pretty good: Doctronics 555 Page.
    As MrChips says, don't give up, when you can design your own circuits or even just understand how a circuit you've made works, it's extremely satisfying.
    Cheers,
    Barnaby
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Don't worry about using space on this server; if the image is too large, it'll tell you.
    Also, it's best to simply put your text in the reply box rather than in the image, as it's a lot of extra work for people to have to re-type your original questions to reply to them.
    Yes, that's correct.
    Resistors limit current, not voltage. Current passing through a resistor causes a voltage across the resistor. E=IR or Voltage = Current * Resistance.
    For simplicity's sake, pin 1 (ground) is considered to be at 0v (ground potential) at all times. This is where the current leaves the IC.
    Pin 3 is indeed the output pin of the 555, and it switches back and fourth between nearly ground and about 1.3v less than pin 8 while in astable operation mode (astable (free-running) multivibrator (square wave oscillator)). Pin 8 is the current source for pin 3, and pin 1 is where the current is sunk to. Transistors inside the 555 connect one or the other to the output.
    Well, capacitors DO block DC current. However, in this case the capacitor is being used as the "C" in an RC network. The capacitor charges from +6v via R1 and R2, and discharges via R2 through pin 7 (which is an open-collector current sink) and finally pin 1.
    Pin 2 is the trigger input (roughly 1/3 Vcc), and pin 6 is the threshold input (roughly 2/3 Vcc).
    When the charge on C1 has exceeded 2/3 of Vcc (6v*2/3=4v), the threshold limit, then the output pin 3 goes low, and pin 7 starts sinking current from C1 via R2, discharging C1. Current is also being sunk from the 6v supply via R1, which is why R1 needs to be 100 Ohms per volt of Vcc or higher.
    When the charge on C1 has dropped below 1/3 Vcc (6v*1/3=2v), the output pin 3 goes high, and pin 7 stops sinking current, allowing C1 to start re-charging.
    Yes; pin 4 needs to be above ~0.8v, or the 555 will be in 'reset' mode and will ignore other inputs. This is usually accomplished by wiring pin 4 directly to the positive supply, or pin 8.
    As explained previously, pin 7 is an open collector output. It is either sinking current (when the output is low) or it is electrically open (near-infinite resistance to ground) when the output is high.
    When the voltage on the cap exceeds the threshold limit, then the output pin 3 goes low, and pin 7 starts sinking current to discharge the cap via R2, as already explained. Changing the voltage on pin 5 changes both the threshold and the trigger voltages.
    It is possible to cause the timer to cease to function if you set the voltage on pin 5 higher than the positive supply, or lower than GND. Decreasing the voltage on pin 5 will caue the frequency of the output to increase, as there is less time necessary for C1 to charge and discharge to the threshold and trigger limits.
    There are actually several subcircuits in parallel. National Semiconductors' datasheet on the LM555 has a schematic of the internals on the 1st page.
    Go to http://www.national.com
    and search for LM555.
  5. grumm
    Apr 28, 2011
    9
    Excellent, thanks gents, I'll start by looking for information about the simplest RC circuits. Believe it or not, I actually understood some of SgtWookie's explanation, so there may be hope for me :)
    Gerard
  6. KJ6EAD
    Apr 30, 2011
    1,426
    363
    The All About Circuits e-book is available to you. You'll see the volume headers on the buttons at the top of the current page. Another good online resource is here:
    http://www.electronics-tutorials.ws/.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    The AAC version of 555 tutorials. Not quite finished, but I'm working on it.
    The 555 Projects
