Millmans Theory
Discussion in 'Homework Help' started by Ndjs, Mar 17, 2013.
  1. Ndjs
    Sep 26, 2012
    18
    Hi Guys,
    I am trying to find the voltage across R3 using millmans theory.
    Any help would be great please see the attachment.
    I am stuck on the next step.
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    It would appear that the next step is to solve for V.
    What is it that it causing you concern?
  3. Ndjs
    Sep 26, 2012
    18
    The maths side of things I am not sure how to get V by itself.
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    Just do the same things to both sides of the equation to get V into the numerator on just one side of the equation.
    You've built yourself a sufficiently complicated equation that you would be well advised to track your units carefully to catch mistakes you make. Also, in the stacked fraction you want to make it clear what is in the numerator and what is in the denominator because 1/(a/b) is NOT the same as (1/a)/b since division is not associative.
    <br />
V = \frac{9983.3A}{41.6S+\frac{1}{ \left( \frac{V}{400A} \right) }}<br />
    The "S" is Siemens, which has units of 1/Ω or A/V and is a measure of conductance.
    So the first step is to get rid of the stacked fraction. Try multiplying the numerator and denominator (of just the stacked fraction) by the multiplicative inverse of the denominator.
  5. Ndjs
    Sep 26, 2012
    18
    Still stuck on how to get it.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    Well, make your best attempt to do what I suggested and we'll get that corrected and take it from there.
