millisecond timer
Discussion in 'The Projects Forum' started by gremlin, Oct 26, 2011.
  1. gremlin
    Jul 22, 2010
    19
    has anyone got a simple circuit for a delay on timer to switch a optocoupler on with an ajustable delay from sao .001 sec to maybe 1 sec
    any thoughts would be greatfully recieved
    thanks
    gremlin
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What is your supply voltage? If it's low-voltage DC, you could use a 555 timer and some parts.
  3. gremlin
    Jul 22, 2010
    19
    hi i can use any supply voltage so long as it will triger a optoisolator i would like to use 9v from a AA battery pack but could go to 12v if needed
    the idea is to trigger a TIP120 transistor via the optoisolator
    the timing delay i was hoping to use a pottentiometer maybe two one caurse one fine ajustment
    i have had a quick look at some 555 circuites on the net and this great site but canot find any with millisecond delay
    thank you
    gremlin
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Something like the attached should work for you.
    It has a range a bit wider than you specified, but that's necessary due to tolerances in resistors/capacitors.
    I didn't show caps across the Vcc/GND terminals of the 555 timer; but you need an 0.1uF/100nF ceramic or poly metal film and a 1uF or larger aluminum electrolytic.
  5. gremlin
    Jul 22, 2010
    19
    many thanks sgtwookie for your time and help i will give that a go tommorow on some breadboard
    one thing i forgot to say was that it will be trigered by a microphone so a single pulse for a millisecond or so when it hears a bang
    then wait the pre set time and fire a 12v dc solenoid via the tip120 transistor it would be nice too for it to only fire once untill a reset button is pressed, the mic will have a simple pre amp so the threshold can be ajusted
    thank you again
    regards
    gremlin
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Oh, silly me - I thought you wanted an astable instead of a monostable. That's a different circuit, but it'll have similarities. I really don't know why I posted an astable configuration.
    Do you have the preamp for the mic built already, and is it working?
  7. gremlin
    Jul 22, 2010
    19
    hi no i dont have the pre amp done as yet but i have a simple circuit to copy from a vellerman mono pre amp kit
    thank you once again
    gremlin
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What is the Velleman kit number?
  9. gremlin
    Jul 22, 2010
    19
    Hi Sgtwookie
    the kit # is
    K1803 Universal Mono Pre-Amplifier
    http://www.maplin.co.uk/k1803-universal-mono-pre-amplifier-2921
    thanks
    i hope to make somthink that will hear the sound of a bang wait the elapsed time of the set duration in milliseconds, then fire a 12v solenoid once via a TIP120 transistor
    and not fire again till re-armed and a bang is heared again to start the process off again
    thank you
    gremlin
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Can't view the assembly PDF at the moment, but Velleman's page for the kit is here:
    http://www.velleman.eu/products/view/?country=be&lang=en&id=8897
    Just so you know; that project uses a 741 opamp which has rather poor performance and requires at least 9v to operate. You would be much better off using almost any other voltage-feedback opamp.
  11. gremlin
    Jul 22, 2010
    19
    hi sgtwookie yes i managed to see the 741 from the pic on the supliers website,
    i dont mind that it is crude and requires 9+ volts as i have 12v available from the battery pack i am going to use on the solenoid,
    it does not matter as i am only looking to get a response from a microphone detecting a bang from a droped item etc so no real audio application is required,
    i was hoping that someone may have a simple circuit etc as i was looking at having to use a arduino micro to do what i wanted , but did not want all the addition of the periferals to run the arduino crystals etc etc
    i was hoping for same simple 2 or three chips and some capacitors resistors etc
    thank you for your kind assistance
    regards
    gremlin
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    After the delay time is elapsed, how long do you want the TIP120 transistor turned on?
    If it's a relay or solenoid, it will take a LONG time to respond. You would likely have to have it on for at least 100mS.
  13. gremlin
    Jul 22, 2010
    19
    hi yes i would gues 250 Ms to be on the safe side
    thanks
    gremlin
