Million dollar idea up for grabs
Discussion in 'Off-Topic' started by maxpower097, Dec 6, 2011.
  1. maxpower097
    Feb 20, 2009
    795
    388
    Ok so I'm reading this about the accident with the model and plane propellor.
    http://gma.yahoo.com/blogs/abc-blog...ren-scruggs-body-mangled-plane-214636964.html
    Then I think could this have been avoided if it were standard law that all small propeller aircraft have LED's embedded into the blade tips that turn on when the plane stops. That way at night time people can see the blades spinning. Like on RC heli's.
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    man that sucks. walking into a giant vertical blender. :(
  3. jimkeith
    Oct 26, 2011
    539
    99
    The LEDs are the easy part--getting power to them is a little tricky--how about a wound stator on the rear hub of the propeller and permanent magnets on the front of the gearbox or engine?
    Better yet: fiber optics running from the tips to the hub, illuminated by a stationary high intensity lamp--opearte only when the engine is running landing gear is down.
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    or a magnet on the plane and a coil on the prop. like a magneto in small engines for the spark.
    EDIT: DOH I said the same thing you said. why did I not realize I was saying the same thing?
  5. jimkeith
    Oct 26, 2011
    539
    99
    @standtor--forgiven--I often fail to read and understand too...
    How do you protect blind passengers?
    Clearly pilot error in my book--how do you keep the plane from crashing? a more relevant issue
  6. maxpower097
    Feb 20, 2009
    795
    388
  7. jimkeith
    Oct 26, 2011
    539
    99
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    In the desert, rotors of full sized helos will emit a blue-green glow near rotor tips when they are worn. An aviation version of "St Elmo's Fire"
    There's a few pictures of them around, look for "Halo" with apache, osprey, blackhawk, etc.
