milliamps to millivolts
Discussion in 'Electronics Resources' started by johner, Nov 7, 2010.
  1. johner
    Nov 7, 2010
    controller makes milliamps as the out put of control,,,, SSR needs input of millivolts, can milliamps be changed to volts with a resistor, if so how many ohms resistor.
    out put is 4-20 milliamps,,, SSR 3-32 volts full range.
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    SSR are 3 letters that mean nothing. Please describe what they are.
    Use Ohm's Law to simply calculate how much current in a resistor makes how much voltage.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Johner,
    Can I assume that by SSR you are refering to Solid State Relay?
    hgmjr
  4. johner
    Nov 7, 2010
    Yes it is thank you.
  5. retched
    Dec 5, 2009
    5,201
    313
    I thought it was Super Studly Retched... ;)
    As for your conversion, if you use a 1 ohm resistor, mA will equal mV
    I keep a 50W 1% 1ohm resistor for just these reasons.
    Get a precision resistor! At such low levels, a 10% or even a 5% will not be very accurate.
