Milliampere - slight difference
Discussion in 'General Electronics Chat' started by ronph, Apr 8, 2013.
  1. ronph
    Feb 4, 2013
    25
    So am building a portable solar kit of two 5 watt solar panels to charge SLA's and 12 volt (10 x 1.2 AA rechargeables) pack. Based on the rated current stated is .32A X 2, I should come out with +/- .64A if connected in parallel. I measured the open circuit and its giving around ~.54A so there is a slight difference. I know the conditions are not always ideal e.g. direct sunlight and PV performance so would the .10A difference really impact the way the batteries are charged say at a constant 14V coming from the charge controller?
    Ron
    Moderators - please move this topic if it merits moving it to another part of the forum.
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    You have a number of flaws in logic and measurement:
    1) Don't take a rating as an exact value. There will always be manufacturing variances that will result in variations in actual measurements.
    2) Solar output is going to vary immensely depending on atmospheric conditions and location.
    3) There is no such thing as an open circuit current measurement of anything besides zero amps. Open circuit means the current is zero. If you are putting an ammeter across the output of the solar panels you are in effect creating a short circuit across the panels and that could not be good for the panels.
  3. ronph
    Feb 4, 2013
    25
    Thanks. I agree that there will be variances in each PV so I am with you on #1 & #2 as earlier stated. As for #3 well, am measuring the current coming out of the charge controller (no load/not connected to the battery) and not the PV per se. Which still does not answer my actual question on the impact of .10A (100ma) difference when charging SLA/battery pack.
  4. kubeek
    Sep 20, 2005
    4,687
    805
    This makes no sense. You cannot measure current by sticking your current meter to the + and - output treminals and looking at the current. You are shorting the output, which will probably destroy the charge controller in a short time.
  5. wmodavis
    Oct 23, 2010
    737
    150
    Yes it will make an impact. How much? You do not provide enough information to provide a complete answer to your question.
