The miller effect is UN-desirable. It quite simply is the magnification of the capacitance between the base and collector of a bipolar transistor (or the gate and drain of a FET) due to the gain of the amplifier configuration.Can someone help me understand what is the Miller effect? And is this effect undesirable or desirable?
Thanks.
It acts like a low-pass filter and will roll off the gain at a frequency determined by the base-collector capacitance, the circuit gain, and the input source impedance.I see, so in what way will it affect the transistor itself? Will it reduce it's gain?
It all depends on what your input & output circuits look like---sometimesThere is more than one intentional use for the Miller Effect. Some IC amplifiers use it for stability at low gains, and some designs use it to limit bandwidth.
This is just a characteristic of active amplifiers and good designs always try to use the characteristics of the parts to the best advantage. Whether it's good or bad depends on what you're trying to do.
Thread starter | Similar threads | Forum | Replies | Date |
C | Miller Effect For Non-Inverting Amplifiers | Homework Help | 1 | |
The Miller Effect in amplifier circuits | Analog & Mixed-Signal Design | 14 | ||
Miller Effect on Cascode Stage | Homework Help | 1 | ||
The Miller Effect | General Electronics Chat | 7 | ||
Explain Miller Effect | General Electronics Chat | 16 |
by Duane Benson
by Jake Hertz
by Jake Hertz
