XC8.Ok it needs to be studied well , let me surf , I will inform you after finish , thanx
by the way , is it written in hi-tech picc ?
Great , you may read somewhere that I have only those pieces I talked about in my hands , 16F84a , 16F677 , Nokia 1100 lcdOP,
This project might be just too much for you right now. As I mentioned in my first post you are probably not going to find exactly what you need. You will need to look at all of the information given to you and modify it to suit your exact needs.
You say you are a beginner. Have you tried more simple projects? Maybe one like writing to a much more simple display like the HDM08216?
Once you learn how to interface to more simple devices, really understand it, learn software / hardware troubleshooting then you can move up to a more complicated device like the Nokia.
Its not particulary simpler since its picky on the timing and how it is powered on and about voltages.It is a simple LCD display. Characters only. Very simple. You send it characters and not fonts. It has it's own font. You can create a few custom characters.
There are many on eBay.
Its not clear what exactly OP "I already done that"
Because OP is not yet showing the code (for 16F84??)
Instead of doing so, and receiving response what needs to be changed, OP is now saying "derailed"?
Can we crystalball where you are at with your coding archievements?
"I already done that" could be almost anything in terms of code.
It takes a lot of discipline getting along with controllers properly, and make progress too.Maybe I am wrong but from what I am seeing OP just copied an existing project and was able to successfully build it. But I could be wrong, as is just my impression.
Ok you are alright may be I wasn't understand the code exactly ,I got this code for CCS compiler and make my own changes till I made it works for MikroCIf you have already done it then it should be a simple matter to to it again. Start with the same font then modify just one character and see what happens.
All of these things are basic trouble shooting techniques that we all do.
Just because you have done something does not mean you understand it. If you fully understood how you did it then it should not be that difficult to change the code to make it work the way you want assuming the device was capable, but then if you understood then you would know it was capable or not.
Thread starter | Similar threads | Forum | Replies | Date |
A | Spwm in mikroc | Programming & Languages | 6 | |
how to put characters in an array | Programming & Languages | 1 | ||
Heart rate code working mikroc pic -- and question | Microcontrollers | 7 | ||
pic mikroc heart rate monitor question | Programming & Languages | 1 | ||
mikroc question usb write data | Programming & Languages | 0 |
by Jake Hertz
by Duane Benson
by Jake Hertz
by Jerry Twomey
