MikroC EasyPic6 - Debug help
Discussion in 'Programmer's Corner' started by Dalaran, Mar 15, 2011.
  1. Dalaran
    Thread Starter Active Member
    Dec 3, 2009
    168
    I recently pulled my EasyPic6 development board off of the shelf do get back into some uC programming. After turning the board on (with no PIC installed) the RB0 LED is constantly illuminated. I can program this pin as a digital output pin and get the LED to turn off. However with it programmed as an input pin, or just there with no PIC loaded it stays illuminated. Seems like something is shorted pulling this HIGH. Anyone seen this before? Any ideas?
    Thanks!
  2. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Do you have the PORTB pullup resistors switched ON?
    Do you have any peripherals selected?
