Mikroc, compile issues with 24bit adc code.
Discussion in 'Programmer's Corner' started by house91320, Feb 8, 2012.
  1. house91320
    Feb 8, 2012
    5
    I'm having some issues with some code than i can figure out, anyone have any ideas?
    72 1506 Implicit conversion of pointer to int MyProject.c
    73 307 Illegal typecast 'can not convert to pointer' '' MyProject.c
    73 1508 Implicit conversion of int to ptr MyProject.c
    74 1506 Implicit conversion of pointer to int MyProject.c
    82 402 ; expected, but 'SPI2_read' found MyProject.c
    82 393 'SPI2_read' Identifier redefined MyProject.c
    Code: Select all
    #ifndef cbi
    #define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
    #endif
    #ifndef sbi
    #define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
    #endif
    long SPDR, PINB, PB4, SPSR, SPIF;
    unsigned long buffer1;
    unsigned long buffer2;
    unsigned long buffer3;
    unsigned long buffer4;
    sbit cs_adc_v2 at LATE4_bit;
    void InitMain() {
    CHECON = 0x32;
    AD1PCFG = 0xFFFF;
    SPI2_Init_Advanced(_SPI_MASTER, _SPI_32_BIT, 64, _SPI_SS_DISABLE, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_IDLE_2_ACTIVE);
    TRISE4_bit = 0;
    cs_adc_v2 = 1;
    UART1_Init(57600);
    // init SPI Hardware
    UART1_Write_Text("LTC2400 ADC Test");
    float volt;
    float v_ref=3.0; // Reference Voltage, 5.0 Volt for LT1021 or 3.0 for LP2950-3
    long int ltw = 0; // ADC Data ling int
    int cnt; // counter
    char t0; //
    char sig; // sign bit flag
    char st1[20]; // float voltage text
    void Main() {
    InitMain();
    cs_adc_v2 = 0; // LTC2400 CS Low
    Delay_ms(1);
    if (!(PINB & (1 << PB4))) { // ADC Converter ready ?
    // cli();
    ltw=0;
    sig=0;
    t0 = SPI2_read(buffer1); // read 4 bytes adc raw data with SPI
    if ((t0 & 0x20) ==0) sig=1; // is input negative ?
    t0 &=0x1F; // discard bit 25..31
    ltw |= t0;
    ltw <<= 8;
    t0 = SPI2_read(buffer2);
    ltw |= t0;
    ltw <<= 8;
    t0 = SPI2_read(buffer3);
    ltw |= t0;
    ltw <<= 8;
    t0 = SPI2_read(buffer4);
    ltw |= t0;
    Delay_us(1);
    Delay_ms(200);
    if (sig) ltw |= 0xf0000000; // if input negative insert sign bit
    ltw=ltw/16; // scale result down , last 4 bits have no information
    volt = ltw * v_ref / 16777216; // max scale
    UART1_Write(cnt++);
    UART1_Write("; ");
    sprintf(volt,6); // print voltage as floating number
    UART1_Write(" ");
    cs_adc_v2 =1; // LTC2400 CS hi
    Delay_ms(20);
    byte SPI2_read()
    SPDR = 0;
    while (!(SPSR & (1 << SPIF))) ; /* Wait for SPI shift out done */
    return SPDR;
    // printFloat from tim / Arduino: Playground
    // printFloat prints out the float 'value' rounded to 'places' places
    //after the decimal point
    void printFloat(float value, int places) {
    // this is used to cast digits
    int digit;
    float tens = 0.1;
    int tenscount = 0;
    int i;
    float tempfloat = value;
    // if value is negative, set tempfloat to the abs value
    // make sure we round properly. this could use pow from
    //<math.h>, but doesn't seem worth the import
    // if this rounding step isn't here, the value 54.321 prints as
    // calculate rounding term d: 0.5/pow(10,places)
    float d = 0.5;
    if (value < 0)
    d *= -1.0;
    // divide by ten for each decimal place
    for (i = 0; i < places; i++)
    d/= 10.0;
    // this small addition, combined with truncation will round our
    tempfloat += d;
    if (value < 0)
    tempfloat *= -1.0;
    while ((tens * 10.0) <= tempfloat) {
    tens *= 10.0;
    tenscount += 1;
    // write out the negative if needed
    if (value < 0)
    UART1_Write('-');
    if (tenscount == 0)
    UART1_Write(0);
    for (i=0; i< tenscount; i++) {
    digit = (int) (tempfloat/tens);
    UART1_Write(digit);
    tempfloat = tempfloat - ((float)digit * tens);
    tens /= 10.0;
    // if no places after decimal, stop now and return
    if (places <= 0)
    return;
    // otherwise, write the point and continue on
    UART1_Write(',');
    for (i = 0; i < places; i++) {
    tempfloat *= 10.0;
    digit = (int) tempfloat;
    UART1_Write(digit);
    // once written, subtract off that digit
    tempfloat = tempfloat - (float) digit;
  2. spinnaker
    Oct 29, 2009
    5,078
    1,180
    It would help if you posted the lines causing each error. Don't expect people to count lines which may not even be accurate.
  3. house91320
    Feb 8, 2012
    5
    sprintf(volt,6); - 73 307 Illegal typecast 'can not convert to pointer' '' MyProject.c
    byte SPI2_read() - 83 402 ; expected, but 'SPI2_read' found MyProject.c
    byte SPI2_read() - 83 393 'SPI2_read' Identifier redefined MyProject.c
  4. spinnaker
    Oct 29, 2009
    5,078
    1,180
    Is "byte" a defined type in MikroC?
    If not that is part of your problem.
    At the top of your code you can try
    #define byte unsigned char
  5. house91320
    Feb 8, 2012
    5
    Ok that got ride of one message, but its still saying
    byte SPI2_read() - 84 393 'SPI2_read' Identifier redefined MyProject.c
    sprintf(volt,6); - 74 307 Illegal typecast 'can not convert to pointer' '' MyProject.c
  6. spinnaker
    Oct 29, 2009
    5,078
    1,180
    Check your header file for byte SPI2_read().
    I'll bet it is something like BYTE SPI2_read()
    In which case match the line in your C file to what you see in the header.
    Look at your documentation for sprintf. That call is totally wrong. For starters you need to supply a character array to print to.
    Remember C is case sensitive.
    Before you go any further I suggest you pick up a good book on C. This is really basic stuff.
  7. PaulEE
    Member
    Dec 23, 2011
    423
    32
    MikroC is great in that you can double-click each function from the library manager list (if you can't see library manager window, go to view-->library manager).
    Here, you can choose which libraries you want to include and double-click for the help documentation on each function.
    unsigned char = 0-255 byte
    Definitely have a look at the library manager stuff. Their help section is second to none. I happen to use MikroC A LOT, so I can help you with specific MikroC stuff if you need
    Some other words:
    SPI2_Read() needs a buffer character in it to generate the clock to read in the data. Example:
    (top of your C code)
    char dummy, data;
    (where you call SPI2_Read())
    data = SPI2_Read(dummy) // Reads a byte from SPI port
    If you simply write "SPI2_Read()", MikroC thinks you're trying to re-define the function instead of thinking that you're calling it.
    Strings in MikroC are char[] type. This is an array of characters. When you see implicit conversion of "int" to "pointer", you're not using the correct data type to display/read/convert strings into. Often, it assumes you're using "int" as the "pointer" (the number that refers to the specific location in your char[] array) since you type it like that.
    again:
    unsigned char[] myData = ""; // declaration of null string, MikroC might not let you do this
    unsigned char[10] myData = (your string); // it usually likes predefined array sizes/values
    Hope that helped.
