mikroc 8.2 multible source file
Discussion in 'Embedded Systems and Microcontrollers' started by walid el masry, May 8, 2011.
  1. walid el masry
    Thread Starter Active Member
    Mar 31, 2009
    132
    hi
    is it possible to separate the source code in c language into multiple source code files and include all of source code files in the same project so that i can use methods in each file without declaring all methods in the same main file to reduce the amount of code written in the main code file
    as example for that i would like to blink a led so there is 4 steps for that
    1- initialize the output pin
    2- set bit and wait for suitable time
    3- clear bit and wait for suitable time
    4- put step 2 & 3 in infinite loop
    Code ( (Unknown Language)):
    1.
    2. // main code
    3. // inti & set & clr are source files to be included
    4. void main(){
    5.  inti();
    6.  while(1){
    7.   set();
    8.   clr();
    9.  }
    10. }
    11.
    1.
    2. void inti(){
    3.  TRISB = 0x00;
    4.  PORTB = 0x00;
    5. }
    6.
    1.
    2. void set(){
    3.  PORTB.f0 = 1;
    4.  delay_ms(1000);
    5. }
    6.
    1.
    2. void clr(){
    3.  PORTB.f0 = 0;
    4.  delay_ms(1000);
    5. }
    6.
