MikroBasic Pro and dsPIC help
Discussion in 'Embedded Systems and Microcontrollers' started by Aussie Nuf Man, Dec 7, 2010.
  1. Aussie Nuf Man
    Nov 3, 2010
    5
    Hey all you super brains (I am yet to become one unfortunately :( )
    I have recently purchased a LV24-33 v6 Development board from MikroElektronika. Came with a PIC24FJ64ga010 MCU. I have installed and got working the MikroBasic for dsPIC (basic language) however I am having problems.
    I have history using qBasic and gwBasic many years ago in DOS (pre windows days) however I am having problems remembering all the different abbreviations, learning new abbreviations and mostly - addressing individual pins. All the examples and literature provided with the package I purchased tends to refer to entire ports as oppose to the individual pins of a port.
    i.e.: I can turn an entire port into an input, and an entire port to output however I am having trouble making the appropriate pins Counters etc.
    I guess my question is: Where and what is good literature for super n00bs like myself. secondly, If I make the software in another basic compiler, will the output .HEX file work with any programmer?
    Cheers,
    Rus.
  2. retched
    Dec 5, 2009
    5,201
    313
    I would head into the Mikroe forums and open the floodgates.
    As for books, you really should get the MikroBasic book.
    http://www.mikroe.com/eng/products/view/476/pic-microcontrollers-programming-in-basic/
    The basic compiler has to support the PIC you are programing for.
    If you try to write a HEX file from a Atmel Basic compiler, it will not work.
