Midi help
Discussion in 'The Projects Forum' started by 1-3-2-4, Mar 25, 2013.
  1. 1-3-2-4
    Thread Starter Active Member
    Dec 26, 2008
    194
    I'm soon to start this project if I can understand it.. it involves using this midi cpu device, but what I can't understand is I want to use a 3 position switch to send control change parameters 82, 83 & 68
    the device is here
    http://store.highlyliquid.com/products/midi-cpu
    and I was reading the firmware manual and if I read right it changes the control change by way of different resistance values? So in that case my switch would also need resistors on it?
  2. kubeek
    Sep 20, 2005
    4,687
    805
    Can´t you point directly to the page that mentions this? I downloaded both the hardware and firmware manuals and I still have no idea what you´re talking about.
  3. 1-3-2-4
    Dec 26, 2008
    194
    Hmm maybe I was thinking of something else.
    on page 50 section 10.1 is what had me confused and more so is how do you tell which CC to send on a switch change?
    I don't think I would need matrix connections because it's just a simple switch
    here is the switch I'm talking about
    The CC's I need is 1 & 68
  4. kubeek
    Sep 20, 2005
    4,687
    805
    Well read the hardware manual page 12, and you will find how to connect the switch.
    1-3-2-4 likes this.
  5. 1-3-2-4
    Dec 26, 2008
    194
    The switch I posted what kind of switch is that?
    I know for the switch to work right it has to have some type of velocity settings, it's being used in a organ software to control the Leslie speed.
    And if I remember right 127 would be fast and anything under 50 would be slow
  6. kubeek
    Sep 20, 2005
    4,687
    805
    Yes that switch should work I guess.
    I am not really sure what you mean with the velocity, read the firmware datasheet section two. From what I understand when the switch on each pin gets on or off, it sends and message that you can set, so with three switches you can send three to six different messages, depending if you want only on one transition of the switch state or both.
  7. 1-3-2-4
    Dec 26, 2008
    194
    Looks like the settings for the switch position would have to be set with sysEx
  8. kubeek
    Sep 20, 2005
    4,687
    805
    Yes, you need to configure the thing each time to start doing it´s job.
  9. 1-3-2-4
    Dec 26, 2008
    194
    It seems the settings are saved on the device.
