if a microwave transmitter normally requires a +8dBm audio level to driave the input fully. if +10dBm is measured what is the actual voltage level measured assuming a 600ohm system
10Db is ten times the power, 3 Db is double the power.if a microwave transmitter normally requires a +8dBm audio level to driave the input fully. if +10dBm is measured what is the actual voltage level measured assuming a 600ohm system
by Jake Hertz
by Jake Hertz
by Jake Hertz
