Microwave oven
Discussion in 'General Electronics Chat' started by legac, Apr 29, 2009.
  1. legac
    May 4, 2005
    54
    Hi
    I would like to know if a microwave oven (Sharp) desiged for 100volts 60cps would be workable with 100 volts, 50cps.
    Your comments are highly appreciated
    Thank you
  2. studiot
    Nov 9, 2007
    5,005
    515
    The machine should work without damage on 50 cycles.
    You may notice a slight reduction in power depending upon the generosity of the internal power supply design.
    If the machine is old enough to use a synchronous timer control, as opposed to an electronic one, the timer will read slow. That is a setting of one minute will actually correspond to 72 seconds.
  3. legac
    May 4, 2005
    54
    Thank you
    Legac
