I have a heating application that works well with microwaves, a full wave transformer capacitor set up works fine but I want to increase the power by using two magnetron's. I notice the current draw using an inverter circuit board is considerably less for the same power. I have tried all sorts of ways to switch on a separated inverter board, through the control signal input/output connections, with no success, can you help? Tony
