Microwave in Electronics
Discussion in 'General Electronics Chat' started by abhimanyu143, Jan 12, 2016.
  1. abhimanyu143
    Aug 25, 2014
    211
    Hello
    I am just looking information about microwave engineering. I saw the some useful information on internet but still I am confused on some point.
    1. what are microwave ? can someone tell me why we need to use microwave ?
    as my understanding , microwave are electromagnetic wave with frequency between 300 MHz to 300 GHz, used in long distance communication
    2. which circuits are the microwave circuit ?
    I think microwave amplifier , microwave oscillator circuit are the example of microwave, example microwave amplifier amplify the microwaves
  2. crutschow
    Mar 14, 2008
    13,505
    3,379
    Microwave is the common name given to electromagnetic waves in the 300 MHz to 300 GHz frequency range you noted.
    It was named for its wavelength (speed-of-light / frequency).
    They are fundamentally no different than electromagnetic waves at other frequencies.
    Microwave circuits are obviously those that operate in that frequency range.
    We don't "need" to use microwaves, they are just frequencies used for many common applications such as Bluetooth, WiFi cell-phone networks, and of course the microwave oven.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I disagree. We need to use microwave communication for spacecraft, because microwaves pass through the ionosphere.
  4. WBahn
    Mar 31, 2012
    18,088
    4,917
    You've answered your own questions.
    1) What are microwaves? A: Electromagnetic waves with frequencies between 300 MHz to 300 GHz.
    2) What is a microwave circuit? A: Circuits that operate at microwave frequencies?
  5. crutschow
    Mar 14, 2008
    13,505
    3,379
    Okay, you got me. :rolleyes:
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Hard to catch you nappin'
  7. #12
    Nov 30, 2010
    16,704
    7,354
    That depends on whether you believe we need space craft.:rolleyes:
    Personally, I think our satellites have done amazing things for our convenience, but I was raised where we had to go get water with a bucket, and I haven't quite moved into the 21st century.:D
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    AFAIK, spacecraft includes satellites. The same radio communication rules apply to them as to maned spacecraft.
  9. Tesla23
    May 10, 2009
    323
    67
    Agreed, but the window is considerably wider than this - it includes VHF/UHF. One of the main reasons we use microwaves here is because the VHF/UHF spectrum is either too congested on the ground or we need more bandwidth.
    This looks about right, from http://www.spaceacademy.net.au/spacelink/radiospace.htm
    There are in fact only two main windows of the EM spectrum that are open to space. One is the visible spectrum, as mentioned above, and the other is the radio spectrum. However, not all of the radio spectrum is useable for space communication. The available window spans from about 30 MHz to 30 GHz, although these are not absolute end frequencies.
    Below 30 MHz, the ionosphere, at altitudes from around 100 to 500 km, absorbs and reflects signals. Above 30 GHz, the lower atmosphere or troposphere, below 10 km, absorbs radio signals due to oxygen and water vapour. Even between 20 and 30 GHz, there are some absorption bands that must be avoided.
    cmartinez likes this.
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Cool diagram, but I didn't immediately grasp that the frequency axis was reversed.
  11. cmartinez
    Jan 17, 2007
    3,698
    2,792
    Maybe it's because it makes more sense thinking in terms of wavelength instead of frequency? So in the diagram, the shortest wavelength lies at the left, and the longest at the right. I would've added a second line of labels to the horizontal axis to make the graphic clearer.
  12. abhimanyu143
    Aug 25, 2014
    211
    sorry for late reply
    1. I saw link https://en.wikipedia.org/wiki/Klystron
    but I don't understand what is klystron, Is it component, circuit, amplifier, oscillator or tube ? can someone tell me what is klystron ?
  13. kubeek
    Sep 20, 2005
    4,689
    806
    FFS read the first paragraph in that wiki article!
  14. abhimanyu143
    Aug 25, 2014
    211
    that means A klystron is a tube which is used as an amplifier or oscillators depend on power
    as we know transmitter is used to transmit signal, receiver is used to receive signal using antenna, waves propagate in free space. i know how transmitter ,oscillator circuit make. but when its time to come in microwave I don't understand how they different from the basic electronics
    I am confused because when we see the amplifier or oscillator in electronics term. first things come in mind that it can be circuit that made with electronics component such as transistor, resistor , capacitors .. etc, but when same words amplifier , oscillator use in microwave why its so difficult to understand,
  15. WBahn
    Mar 31, 2012
    18,088
    4,917
    The biggest difference is that at microwave frequencies you can no longer treat components as lumped elements or assume that the voltage on a wire is the same everywhere along the wire. The wavelengths are on the order of or shorter than your components and interconnects. So you have to treat everything as distributed. That greatly complicates the math. But it also opens up doors that were previously closed to the designer and no just how you layout a conductor on a printed circuit board becomes a filter or other circuit component. Of course, the reverse is true, conductors on a printed circuit board (or elsewhere) that you only wanted to be a conductor act as unintended filters or other circuit components.
  16. Kermit2
    Feb 5, 2010
    3,852
    968
    We always just called it RF plumbing. Waveguides and resonant cavities. Just a bunch of copper pipe through which we could push a full megawatt of microwave RF.
    Feedhorns and reflector dishes, LNA's and (for our OP)
    A klystron used as a local oscillator inside a special signal generator which simulated moving target echoes for use in signal injected troubleshooting of the video and doppler portions of the receiver section.
  17. alfacliff
    Dec 13, 2013
    2,449
    428
    satelites have used frequencies lower than microwaves for years. vhf, uhf, and even short waves. a lot of russian satelites used a frequency just above the 10 mhz frquency.
