How do you mean "inside the filter"? Do you mean physically inside the filter from an externally irradiated source?Hi Dave,
Thanks for the paper.
Can anyone tell me how to find the maximum electric field intensity inside the filter using any 3D simulator??
Yes, quite easily. What sorts of frequencies are we looking at?Hi Dave,
Yes you are correct.
Take an example of Round rod interdigital bandpass filter. So if I connect the source to the filter, then what will be the maximum electric field intensity inside the cavity of the filter?
Is there any way to find out this using any 3D simulator?
If you can get access to it, Ansoft HFSS is ideal for this type of HF problem, you will be able to model all field parameters (including your own mathematically derived functions), but specifically E/H intensity and power density distribution. For anything in the microwave frequency band this is what I use, and I use Maxwell 3D for anything in the RF range.Hi Dave,
I have designed a filter at 2 GHz with 8% bandwidth.
Can you suggest any effective 3D simulator which I can use to find out maximum field intensity inside the cavity of filter and maximum power handling capability of the filter?
