Microswitch
Discussion in 'General Electronics Chat' started by DexterMccoy, Apr 21, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    They call it a Microswitch , but it's a big switch that has a coil
    The coil is 28 volts DC to turn it on , energize it
    I don't understand why would a design or circuit want a switch to have a coil to ENABLE the switch
    Any reason why?
    Here is 3 things that I don't understand
    1.) Hold Voltage?
    2.) Drop out voltage?
    3.) Steady State limit?
    What does these terms mean?
    Why would you want a switch to have a hold voltage?
    Why would you want a switch to have a drop out voltage?
    Why would you want a switch to have a steady state limit?
  2. DexterMccoy
    Feb 19, 2014
    429
    I think the switch brand name is called Microswitch
    It need 28 volts applied to the internal coil inside the switch to make the switch work
  3. DexterMccoy
    Feb 19, 2014
    429
    SPDT plus a Coil
    If you don't energize the coil, the Switches doesn't work
    My question is why would anyone want a SPDT or DPDT switch that has a coil to be enabled or energized to work?
    You have to manual flip the switch but it has to be enabled / energized to make it work in both positions of the switch
  4. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I think his switch turned into a relay so the switch question is done.
Thread Status:
