Wire usually works best. String or tape will make the connection but won't work well.i would like to know how to connect 2 microswitch to the input J and K for a JK flip flop .
is it possible for you to draw out the schematic diagram for me to understand better ....If you use the Normally Closed contact tied to the J or K input, place a pull-up resistor to the inputs of the J-K and the other side of the switch to ground. Pushing the switch will cause the J or K input to go high. Otherwise, if you use the Normally Open side of the switch, place a pull-down resistor to the J and K inputs of the J-K and tie the other end of the switch to the +5 volts. How are you going to clock the J-K?
by Jerry Twomey
by Duane Benson
by Duane Benson
by Jake Hertz
