Microprocessors
Discussion in 'Homework Help' started by hada, Sep 27, 2008.
  1. hada
    Sep 24, 2008
    15
    hi,
    i have a big problem fromwhat i see,i have been given a task to make a code.i have to suppose that multiply operation is not available on 8086/8088 microprocessors and by using all of the rest operations make a code to multiply two numbers.
    :confused:
    can any one have a idea how to do it.i tried it by adding any the series of numbers.
    n please recommend a good book on digital communication systems.i have tried but proakis book is not available.
    thanks
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    If you have two numbers, x and y, you can multiply these by adding x to itself y-times (or conversely add y to itself x-times).
    Eg: 3 x 4 = > 3 + 3 + 3 + 3 => 4 + 4 + 4
    Dave
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The 8086 does have a multiply instruction.
    In any number base you can multiply by shifting and adding. In binary it is actually fairly efficient and the exection time does not depend on the magnitude of either operand.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Page 7 in the tutorial at this link describes the IMUL instruction.
    hgmjr
  5. veritas
    Feb 7, 2008
    167
    I think he means that he knows the multiply op exists on the 8086, but he can't USE it for the assignment. Adding or shifting/adding, as suggested, will work for this.
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    Your interpretation may be correct but in the introductory post of this thread the statement does not clearly state this to be the case.
    hgmjr
  7. scubasteve_911
    Dec 27, 2007
    1,202
    It doesn't? :p
    Steve
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Basically we're talking about a simple loop by X times. This is fairly basic if you approach it as such.
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    That is a charitable interpretation, but inconsistent with the OPs actual words.
  10. hgmjr
    Jan 28, 2005
    9,030
    214
    I, for one, look forward to getting a clarification of the original question when she/he returns.
    hgmjr
  11. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    I must say, this is how I interpret the OP. The word that gestures towards this is "suppose" when referring to the availability of the multiply operation.
    My interpretation is that this homework question is looking at using loading registers with values and using adding (and shifting) along with GOTO and BRANCH statements to implement a simple multiply operation.
    Dave
  12. hada
    Sep 24, 2008
    15
    yup u r right.i have to suppose for my assignment that its not available.n thankz to all ov u
