microprocessor
Discussion in 'Off-Topic' started by loosewire, Mar 21, 2009.
  1. loosewire
    Thread Starter AAC Fanatic!
    Apr 25, 2008
    1,584
    435
    My impression on how thousands of transistors work together to
    form a working curcuit. I think you would need to have resistance
    and capacitance.Since resistance create heat,most of the resistance,
    could be outside the component. The conduit to connect the transistors
    using internal components would not be able to conduct heat.
    Now we have to put a 1000 transistors in a small space. Now I have to put
    my 1000 transistors into appox 1"x1" space.I have to find a medium to do it
    and not short every thing out. What about a very thin film ,which is an insulator and print
    the curcuit on the film.(no heat).The film would have to be super,super thin.
    How about some math help,how thin can you go. We will be pressing this film together
    because we have a lot transistors put into curcuits. Every heard of natural resistance,
    reactance. You want find this on google. Copyrighted while I rest brain.
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Have you studied MOSFETs?;)
  3. loosewire
    Apr 25, 2008
    1,584
    435
    I am staying away from I word,working this through my exposed
    mind. Will accept guildance. Don't think I have ever seen this attemped step by step. Students in
    your left hand you have 5 transistors,in your right hand you a have computer chip with with
    hundreds of transistors. I trying to explain,ask some questions about space,try to picture
    from is inside the chip. No one liners ,explain to me step by step how your computer chip is put together
    without using brand names,must be your own work.
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Here's how we do it in Oregon: http://www.intel.com/education/makingchips/
    Not in my own words, of course, but a much better presentation than I am willing to attempt!
    And, oops! I used a brand name. Shame on me. :D
  5. loosewire
    Apr 25, 2008
    1,584
    435
    I have no source, I am letting members think about what make sense.
    In your position I don't want to play hot and cold with your key chain.
    I am going with the film theory for now and how each piece get connected.
    I want to see if some students want to connect the dots.I can envision
    the men and women in white lab coats,using electron microscopes
    veiwing the curcuits on film,since every thing don't have to be on
    at once,less resistance,less heat.Maybe the film could be folded over,
    and press together making a complete curcuit Inside the chip.
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Thank you. I have enough trouble keeping track of my key-chain as it is.:cool:
    The clean-room suits are not all white. Some of them are a light blue, and some are orange!
    There is no "film." There is a big glass disk. (Actually, there are many many big glass disks, but let's look at one at a time.) It gets cleaned, masked, impregnated with stuff, masked again, etc. Lots of nasty chemicals are used in tightly controlled quantities.
    Then it gets sliced up. Then very very thin wires get soldered to it. Next comes the gigantic plastic package we are all familiar with.
    Robots do most of the work.
  7. loosewire
    Apr 25, 2008
    1,584
    435
    Thanks, you may to the head of the class, 1-Gold Star.
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Gold stars are not allowed in the clean-room. Only approved adhesives may be brought through the vestibule.:D
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    Starting from scratch wouldn't be pretty.
    The first Texas Instruments IC, a Germanium transistor with biasing resistors, doesn't look like it was made in a clean room. Circa 1958
    The "slab" is 1/16" x 7/16"
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Bonding wires to raw chip stock is what I do. It's not soldering, but it does seem like voodoo sometimes. They use ultrasonics and heat (not even close melting points) to fuse gold and/or aluminum.
    Come to think of it, there is a soldering technique, but I don't have much to do with it. They flip the chip upside down, and solder it with indium solder bumps. Indium has a very low melting point.
  11. loosewire
    Apr 25, 2008
    1,584
    435
    What german company makes transistors?
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    Telefuncken? Siemans?
    Is this a trick question?
  13. loosewire
    Apr 25, 2008
    1,584
    435
    Old english,my way faring friend.
  14. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I don't get it. What does auld Angle have to do with Deutsch-Transistoren?:confused::confused::confused:
  15. loosewire
    Apr 25, 2008
    1,584
    435
    Bill,speaks old english when he wants.I never know ,he a busy man
    I 'm always happy to see him on a post,to check out my old english.
    I have to get back on tract, I'm thinging more about time than space
    now,do they still lift grounds to turn transistors off,I'm trying to express
    this right. Switching transistors on and off as needed,in multiple
    curcuits. I'm thinking that all curcuit are not on unless needed ,result
    less resistance and less heat. My goal is have linear mental picture in
    time and space from computer log on to A.C.C. log on so members and
    guest can get brief C.S.I. look at the process,like when hardware and
    sofeware curcuit are working at the sametime.When working separate
    ,another way would be at the same time view the computer screens as
    if you were turning loose leaf pages with brief thoughts with each page
    turned.Try to get my thought before you shoot it down.Maybe the guys
    would jump in,it don't have to be a rush thing.It will pick up or die.
  16. thatoneguy
    Feb 19, 2009
    6,357
    718
    If you could get an exposed CPU die, and a thermal imaging camera, it would be interesting to see which areas consume power while doing different operations. The temperature gradient would be slight, but the modern imagers are pretty good with discriminating very slight temperature differences.
  17. loosewire
    Apr 25, 2008
    1,584
    435
    If a lot members like you with bits of information,we can see with
    common sense what is going on.In stead x-raying the chip we go for
    what is being display. Like I said (real quick) picture that linear view
    of( log on computer) to( log on A.C. C.) all along this linear curcuit
    look on-Picture each screen as a loose leaf sheet of paper,where
    a page can be moved around.So if we don't have members and guest
    that can look at each screen and say this or that is going on.
    As you image this high speed linear curcuit,think time & speed.(No links)
    I have been asking questions,you can ask questions.
    Some one could start with page #1 - log on hardrive #1-b -log on software,
    Block diagrams,and thumbnails programs ,is each a piece of seperate software
    like google ,google earth,internet explorer image turning a page to go to
    google earth,turn page go to home-type in A.C.C..If some member could make
    a thumbnail index page that would help make this work.That way every view would have
    a place.Close your eyes an view this linear path with easy to explain pages.
  18. loosewire
    Apr 25, 2008
    1,584
    435
    0Just turned computer on,power supply working,pressed internet explorer.
    Home page appeared ,selected A.C.C. favorite.Now have blue screen
    has appeared-screen name.(On hold) Waiting for short explaintation
    about hardware & software in use where.no binary simple terms,please
    no jokes.Create thumbnail #-1. Example-A.C.C.-software-power supply
    hard ware.use your createtive mind to make this work for non-experts.Moderators please monitor.A sample log on screen would help,so you get a quick view with arrows (harddrive-software or both.(down load to hardware -that mean a software) so lets picture that conduit of files going to hardware back to your thumbnail and page(screen)
