Microprocessor on off heating control
Discussion in 'The Projects Forum' started by Useraz, Oct 13, 2013.
  1. Useraz
    Oct 13, 2013
    I need to make a homemade toster oven for a college project. That uses a microprocessor. I discovered the max3155 chip that communicates directly from the thermocouple to the microprocessor but I need help with the circuit. I was thinking of using a relay for the on off controll. My element runs off 120 what can I use to lower the voltage so that my microprocessor gets only it's 5 volts but element still having 120 without using a transformer
  2. tracecom
    Apr 16, 2010
    3,878
    1,396
    What microcontroller family are you familiar with, and what language do you code in? Why do you want to use a thermocouple?
  3. crutschow
    Mar 14, 2008
    13,475
    3,362
    It would be better to use a solid-state relay since they are silent, have a very long life, and are easy to interface to a computer.
    You need isolation from the power line to your microprocessor power for safety. A small line-powered switching regulator can do that, such as a wall-wort supply.
    Useraz likes this.
  4. Useraz
    Oct 13, 2013
    I just started to learn microprocessors it's been a couple of weeks in school.. So far we been using microcode programme with the pic16f877 and 16f873. I forgot to mention I'm using the thermocouple cause I need to display the temperature on a LCD so that I can change the setpoint up and down with push buttons
  5. tracecom
    Apr 16, 2010
    3,878
    1,396
    Microcode Studio is what is called an IDE (integrated development environment.) It is often used with the PicBasic Pro compiler. Does that sound familiar?
    At what temperature do you plan to switch the heating element on and off? Are you going to work in Celsius or Fahrenheit?
    Unless you are required to use a thermocouple, there are probably better choices. You could use a thermistor in a voltage divider arrangement, or you could use a dedicated temperature sensor, such as an LM34 or LM35.
    Are going to interface with your LCD using parallel lines or a serial adapter?
  6. #12
    Nov 30, 2010
    16,665
    7,310
    You can't.
    At least not on this site. Powering off the 120 volt supply with no transformer is not allowed here because it is not safe.
  7. tracecom
    Apr 16, 2010
    3,878
    1,396
    If you don't have, or don't want to build a 5V power supply, you can simply use 3 single cell alkaline batteries in series. The batteries can be whatever size you want (AAA, AA, C, D.) I would use D cells to get the longest life.
    Useraz likes this.
  8. #12
    Nov 30, 2010
    16,665
    7,310
    I didn't think of that.:(
  9. GopherT
    Nov 23, 2012
    6,303
    4,019
    A Toster oven will have to get the bread warmer than 200C (approximate) to start toasting. The LM34 and LM35 will be toasted at those temperatures.
    absf likes this.
  10. tracecom
    Apr 16, 2010
    3,878
    1,396
    Researchers have determined that the perfect piece of toast is produced when the bread reaches a temperature of 154°C, http://www.dailymail.co.uk/sciencet...st-2-000-slices-216-seconds-optimum-time.html which is only a little above the max rated temp of the LM35 and LM34. I have never used either one at that temperature, but it would be worth a try.
    However, I see your point.
    absf likes this.
  11. Useraz
    Oct 13, 2013
    Yes we are using the pic pro compiler. And I have to have the heating from 0-350 degree Celsius or equivalent in Fahrenheit . And the thermocouple has to be used cause it is in the specifics of my project
  12. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    If needing to accurately control temperature this way you will need to include some kind of PID loop, if using a SSR this is either on or off, so the loop would need to detect when the set point approaches and start to cycle on/off in order to obtain stable temperature.
    If using phase angle (TRIAC) control, you MAY get away without the PID feature but the switching will be electrically 'noisy'
    Max.
    absf likes this.
  13. tracecom
    Apr 16, 2010
    3,878
    1,396
    I don't have any experience with thermocouples, so I can't be much help there. Maybe I can help with the code when you get there.
    What about the LCD? What size is it, and are you interfacing the PIC using multiple pins (parallel) or only one pin plus power and ground (serial)?
