microprocessor archeticture
Discussion in 'Embedded Systems and Microcontrollers' started by hamran, Dec 14, 2006.
  1. hamran
    Aug 21, 2006
    10
    hi everybody
    i dont understand that the 8086 i said to be 16 bit microprocessor but its ram is 20 bit long for addressing and the registers is 8 bit long.....could u plz help me understand the archeticture
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The 8086 was a horrible kludge, as was the IBM 5051 computer, and MS DOS.
    Your best bet for data on the 8086 is to go to Intel and get the huge spec sheet on the device. They built it, so they are the best source of information.
    This must be a purely academic interest - right? Surely you are not planning to actually use one? I have a leftover 386 plus math coprocessor I'd happily donate to spare you that agony.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The 8086 architecture can process data in byte size(8 bits) or word size(16 bit chunks). The size of the address bus(20 bits) has nothing to do with the data size. Who ever said that it did?
    AX is the 16 bit accumulator, AH and AL are the uper and lower halves.
    Similarly for BX, CX, and DX
    BP Base Pointer
    SP Stack Pointer
    SI Source Index
    DI Destination Index
    are all 16 bit registers with no ability to manipulate byte size data
    CS, DS, SS, and ES are all 16 bit segment registers used in segmented addressing.
    A horrible kludge eh. Und how many successful microprocessor designs are you responsible for Herr Doktor? Ja zero - I thought so.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Unsuccessful as charged, but the 8086 was still a kludge. If IBM hadn't put its imprimitur on the chip, it would have been eclipsed by the 6800.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Did you mean the 68000. The 6800 was an early 8-bit offering. As I remember the big knock on the 68000 was that at 64 pins it was like putting an aircraft carrier on a PC board. The cost differential was sustantial. IBM correctly saw that hardware architecture was very nearly irrelevant. Software was everything. If you have the right software the hardware doesn't matter.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Yep, dropped a zero. And yes, nobody cared a bit about the computer's innards. Many strange things happened with early desktops.
  7. Sirropo
    Nov 24, 2006
    Yes, 68000 was the better chip, Intel just happened to be at the right place at the right time to get their 8000 series chip its historical jump start.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    No argument there.
