Microphone outputting constant voltage?
Lilrayray
Joined Feb 21, 2009
31
Hmm, Ive been doing a bit of searching and I read that the resistor should equal the microphone impedance, which in this case is 680. Is this incorrect, an over simplification, or...?
Audioguru
Joined Dec 20, 2007
11,248
Nearly every electret mic is powered from a decoupled 10k resistor from a 9V supply. Then their current is 0.5mA (like on their datasheet) and they have a voltage drop of 5.0V.
When the powering/load resistor is less then the output level is less. I measured many electret mics to have a 3.3k ohm output impedance that becomes 2.5k when in parallel with the 10k powering/load resistor.
Please post your complete schematic showing how you power the mic.
Lilrayray
Joined Feb 21, 2009
31
Here is what I currently have built. I guess I will replace the 680 ohm resistor with a 6.8k ohm and couple the power supply to ground through a capacitor.
EDIT: Will a 5V power supply be adequate, assuming I choose a resistor value to match the necessary current?
EDIT2: replacing the resistor with a 10k ohm resistor certainly made it more responsive.
