microphone interfacing
Discussion in 'The Projects Forum' started by jcd, Mar 7, 2011.
  1. jcd
    Mar 7, 2010
    sir,
    i am working on project involving location of sound source.I need to take data from at least 4 microphones ,but computer sound provides only 2 channels.I was wondering if one could send two signals through same channel so i can get 4 signals into computer and then extract the signals.I am using MATLAB to process signals.
    thank you
  2. wayneh
    Sep 9, 2010
    12,396
    3,246
    A digital audio port can handle at least 5 channels.
    I don't think you'll ever want to mix the audio channels, thereby losing the very thing you want to measure.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You could multiplex four channels into two using some circuitry, like perhaps a 4066 quad switch - of course, that means you'd need to use a USB or other interface to control the switch.
    Basically, you'd have four mics facing into a parabolic reflector in a "+" pattern. Switch in the high and low mics (Y-axis) and listen for a few milliseconds, steering the antenna in the Y-axis towards the sound. Then switch to the left and right mics (X-axis) and steer the antenna in the X-axis towards the sound.
    Of course, that's a good bit more complex than using a sound card that has sufficient channels.
  4. bribri
    Member
    Feb 20, 2011
    133
    5
    a soundcard with 4 or more input might not be too expensive.
    otherwise you might matrix the sound with some wacky phase-shift encoding like dolby pro-logic or M+S recording.
