microphone conditioner
Discussion in 'General Electronics Chat' started by bug13, Nov 11, 2014.
  1. bug13
    Feb 13, 2012
    1,213
    38
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    it is used to compress the signal from the microphone (compression changed the peak to average signal level) , this gives more aparent output, but also distorts the signal a bit. it also has an automatic gain control circuit that tries to hold the output signal level constant.
    bug13 likes this.
  3. wmodavis
    Oct 23, 2010
    737
    150
    As stated in that 'understood' description... to improve vocal clarity & to provide adjustable compression characteristic. Also to provide preamplification &/or buffering of microphone plus automatic limiting all in a single IC.
    And it is not really needed. You could do all that with several 12AX7s.
    bug13 likes this.
