I have an old micronta analog type multi meter. it is not registering DC V correctly it seems to be about 2-3 V low compared to the what the power supply shows. it has a few trim pots but no way to really tell what is what since theyre 3. i think 1 for each DC V ACV ohms. have slightly adjusted them with no luck. checked all resistors to me they seem ok. this is in the word 03 doc attachment. are these values ok? will try the trim pots some more also to see where i get.
I also noticed today when testing it I had the source at 0 V but on with leads connected the meter went off the scale reverse. i reversed the leads with 1 V and it did the same but then it the issue became almost negligible. it seems i have seen something similar before I assume there may be something odd going on in the meter part. Something gets magnetized or something and reversal almost fixes it.
If I cant, figure it out after some more work i may just part it out it seems pretty old, but be nice for a toolbox. Since I normally use a big bench style meter. but i have another that seems to work decently.
