Microcontrollers 8 bit
Discussion in 'Embedded Systems and Microcontrollers' started by Nathan Hale, Aug 9, 2016.
  1. Nathan Hale
    Thread Starter Active Member
    Oct 28, 2011
    125
    Hi folks, what does the "8 bit" in a 8 bit microcontroller mean? thanks
  2. nsaspook
    Aug 27, 2009
    3,021
    2,386
    Robin Mitchell and joeyd999 like this.
  3. cmartinez
    Jan 17, 2007
    3,700
    2,802
    It means that its instructions, an its I/O arrangements are performed in groups of 8 bits, like 8 zeroes and ones, which are normally called a byte.
    One of the most popular 8-bit MCU's out there is the 8051, of which there are many brands.
    Have a look at its instruction set, and standard architecture.
  4. dannyf
    Sep 13, 2015
    2,196
    417
    The databus is 8bit wide. It's instructions can be longer (typically).
    ci139 likes this.
  5. vead
    Nov 24, 2011
    621
    8
    You can deal with 8 bit data. Example you can add, subtract 8 bit data
    xxxxxxxx+xxxxxxxx=xxxxxxxx
    8 bit data+8 bit data= 8 bit data (output)
  6. NorthGuy
    Jun 28, 2014
    611
    121
    Nothing if you program in C.
    If you program in assembler, you wouldn't ask.
    Robin Mitchell likes this.
