1. priyanksaxena555
    Oct 7, 2013
    At present I'm working on both humidity, temperature display and control project for continuous working application.
    I am using atmega 16l microcontroller and it is working perfectly but I'm having doubt on its continuous working i.e round the clock.
    Please guide will it work perfectly in my continuous working application or should I switch to some other option.
  2. sirch2
    Jan 21, 2013
    1,008
    351
    Nothing is going to be "perfect", why would it not work reliably for a long period of time? Why is the MCU more likely to fail than your other components?
  3. priyanksaxena555
    Oct 7, 2013
    Dear sirch2
    Thanks for your prompt suggestion.
    My question is just about that microcontroller atmega16l can work 24*7 continuously for months. And on your question on my other components those sensing ic's which I'm using can work continuously.
    Please reply with microcontroller working conditions and its continuous working capability.
  4. sirch2
    Jan 21, 2013
    1,008
    351
  5. MrChips
    Oct 2, 2009
    12,636
    3,454
    Stay within the manufacturer's operating conditions for supply voltage, temperature, humidity, clock frequency, power dissipation, input and output currents and voltages.
    The chip should run non-stop for more than 300 years.
    priyanksaxena555 likes this.
  6. Art
    Distinguished Member
    Sep 10, 2007
    797
    61
    The Flash Data Retention Time in the datasheet is what you want to look for.
    The micro won't do anything if it's not running a program.
    How many times the device is power cycled, and subject to thermal expansion.
    There is also a slim chance a microcontroller can be erased when it is powered up.
    Atmel is prone to this.
    Other things will more certainly break.
    Electrolytic caps will dry out, relays will get stuck, or kill an IO pin if it wasn't protected,
    solder joints themselves can become problematic after a decade or so.
