Microcontroller
Discussion in 'General Electronics Chat' started by sam_1988, Jun 17, 2011.
  1. sam_1988
    Jun 17, 2011
    Hey i am looking to build a quadrature encoder and i was wondering if i could use a microcontroller to create the outputs or do i need a separate input?
    Also if you can what would be the best microcontroller to use?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A quadrature encoder is usually an electromechanical device - http://en.wikipedia.org/wiki/Rotary_encoder
    Perhaps you mean to use the microcontroller to input the signals?
    With no knowledge of the end use, it's about impossible to suggest a device to use.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Microchip posted a Technical Bulletin for using a PIC10F2xx uC as a quadrature encoder simulator.
    Link: http://ww1.microchip.com/downloads/en/devicedoc/91091A.pdf
    Source code is available here: http://projects.mestcs.com/idcplg-IdcService=SS_GET_PAGE&nodeId=2121&fragment6_NextRow=326.htm
    Here's a quadrature decoder using flipflops and a few gates: http://www.fpga4fun.com/QuadratureDecoder.html
    Here's a simple quadrature encoder circuit using phototransistors and Schmitt triggers:
    http://keeganmann.wordpress.com/2011/01/02/quadrature-encoder-circuit/
    You could use a 4093 quad NAND Schmitt trigger for that portion of the circuit.
    You could probably build a quadrature encoder simulator using some D-type flip flops with a clock input.
  4. ErnieM
    Apr 24, 2011
    7,447
    1,628
    A separate input for each output is always a requirement, but only in professional plumbing applications.
    :D
    (try posting again, as your post needs more sense: your post makes none.)
  5. nickelflipper
    Jun 2, 2010
    280
    35
    Microchip has a few devices that have QEI modules for processing the velocity and counts from the encoder, such as the PIC18fxx31 devices. See Microchip MAPS.
  6. sam_1988
    Jun 17, 2011
    Thanks for all your input guys i will have a look and see if i can get a working model! I will post my results! Thanks again!
