microcontroller
Discussion in 'The Projects Forum' started by andrew.benasa, May 8, 2009.
  1. andrew.benasa
    Apr 29, 2009
    please help me in the design of my project involving the use of microcontroller. can you give me any simple project design to construct. Note that it should be simple to construct and must be attainable..
    please........
  2. KMoffett
    Dec 19, 2007
    2,586
    234
    Andrew,
    Please do not post the same question multiple times. http://forum.allaboutcircuits.com/showthread.php?t=23238
    It will confuse you and those that might answer your request. Half an hour is not a long time to wait for a response. Remember half the people on this furm are asleep at any given time. ;)
    Ken
  3. RiJoRI
    Aug 15, 2007
    536
    26
    IF you have never worked with assembly language before, I would suggest that you look at the BASIC Stamp by Parallax, or the Arduino board. Both have projects that range from blinking an LED to rather sophisticated ones. Both are pretty much "plug-and-play".
    --Rich
  4. KMoffett
    Dec 19, 2007
    2,586
    234
  5. StarfleetRP
    Member
    Mar 23, 2009
    24
    The pics from microchip are fairly easy to program since they are c based. There a a lot of start-up examples available and there are also microchip demo boards that you can buy (although a bit expensive).
