MIcrocontroller with free compiler
Discussion in 'Embedded Systems and Microcontrollers' started by bharadwajtk, Mar 22, 2015.
  1. bharadwajtk
    Mar 22, 2015
    Which all microcontrollers are there(with wifi, BLE or Zigbee support), which don't need the IAR Workbench for programming and which is the free compiler I can use with them?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    There are undoubtedly free compilers available for all processors. While it sounds like a nice thing there can be drawbacks. Lack of available support is probably one of the biggest. If you make commitments to deliver a product and cannot meet those promises because of compiler problems, you're on your own. It might prove to be a false economy. The use of a free compiler might save you a couple of thousand dollars and cost you half a million. Free compilers are not for newbies or people on a tight schedule. You just don't have the luxury of being able to delay things while you come up the learning curve or work out operational problems.
