Microcontroller usage
Discussion in 'Homework Help' started by Poul Meinhard Poulsen, Oct 30, 2014.
  1. Poul Meinhard Poulsen
    Oct 27, 2014
    5
    Hi
    I'd like to make a small survey, about which microcontroller you use, and from which nation you are from.
    this is suppose to be used in a project we're doing.
    If you would like to specify why, you use these microcontrollers, then you are welcome to do that.
    Or if you have a history of another microcontrollers that you've used, you would be welcome to share that too.
    thank you in advance
    Best Regards
    Poul M. H. Poulsen
  2. ISB123
    May 21, 2014
    1,240
    531
    I use Atmel MCU's, most of them are ATtiny or Mega.
    I use Atmel ones because I have Ardunio which can program AVR chips so I don't have to buy dedicated programmer.
    Usage: CNC controllers,PC input devices and for some other "simpler" projects.
  3. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Thats funny, essentially the Arduino is a programmer. There are also USBASP programmers, some smaller Arduinos dont have USB.
  4. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,529
    In the past PDP11, Intel 8085.
    Currently Microchip 18F series.
    Small powerful instruction set.
    Peripheral capabilities.
    Availability.
    Support.
    Cost.
    Centre of N.A. Canada.
    Max.
  5. lightingman
    Apr 19, 2007
    374
    22
    Hi.
    Daniel, South Wales, UK.
    PIC16F and 18F series now.
    In the past NS8750PD-11 piggy back MCU.
  6. MrChips
    Oct 2, 2009
    12,657
    3,461
    I have used 1802, 6502, 6800, 6801, 6802, 6805 6809, 68000, 4004, 8008, 8085, 8088, 8086, Z80, MC146805, 186, 286, 386, 486, 8035, 8051, 68HC11, AVR, PIC, HC908, HCS08, TMS320, ADSP-21992, DSP56F807, MSP430, STM32F407.
    Did I forget something?
  7. WBahn
    Mar 31, 2012
    18,094
    4,920
    Interesting homework problem.
    I don't do a lot of microcontroller work (mostly ASIC design), but when I do I use the PICs because it is what I am familiar with and as long as they meet my needs I can't justify the overhead of switching. I primarily use them in test systems to test our ASIC designs.
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
    Microchip PIC's, because when I started there were tons of tutorials for them, like Nigel's and Easy PIC'ns. I had an early Ti 99/4 (Ti Basic) and had used Microsoft basic (early PC) at work. Twenty years later, I was just too old and lazy to learn a new language. MPASM has done fine by me. I don't consider the cost of PIC programmers in the least bit significant. I started with PICStartPlus, which was great, then used PK3 for a short period (lousy power supply), now I use an ICD3. Basically, it works and does what I need. Why change?
    John
  9. Brevor
    Apr 9, 2011
    282
    56
    Intel 8048, 8051, 8052
    Microchip 12F and 16F
