So this is a bit of a hardware/software mashup question
I recently got a neat $5 infrared keyboard from goodwill, and I'm trying to make a receiver for it.
Right now I have an arduino UNO with an IR reciever, and I have this code to decode the signals-
this is using this library.
it successfully decodes things into values (hex or dec or whatever I choose), which I need to correlate to specific keys
it seems that each key has a "Key Down" value that is transmitted when a key is pressed, and a different "KEY Up" value, transmitted when a key is release, and then when all keys have been released the keyboard transmits another code, i would assume to communicate that no keys are being pressed anymore
my question for the more experienced is this,
what microcontroller should i use for going forward, as I would like to build a simple pcb with the microcontroller on it to just plug into a USB port
I have heard varying stories of arduinos versus other uC's being able to communicate using USB keyboard protocols , and was wondering if anyone had any advice
Thanks!!
Rich (BB code):
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
double previous = 0;
double end_one = 4146893829;
//double end_two = NEED_OUTPUT_VALUE;
double output = 0;
void setup()
Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
void loop() {
if (irrecv.decode(&results)) {
if (results.value == end_one) {
Serial.println("end_all");
}else if(results.value != previous){ //if it is a useful value
Serial.println(results.value);
//output = findChar(results.value);
previous = results.value;
irrecv.resume(); // Receive the next value
double findChar() {
double code = results.value;
//NEED CODE TO FIND CHARACTER/COMMAND DATA FROM VALUE
//POSSIBLY MAKE AN ARRAY OF CODES, WITH THE ELEMENT CORRESPONDING TO THE ASCII VALUE
if(results.value /*within bounds of ascii characters*/) {
//return value of ascii character
//or code for keyboard command
//or execute keyboard command from here
}else if(results.value /*volume or other such command key*/) {
//return command information, or do command, or something
}else if(results.value /*shift key or function key or other such key, need to look at keyboard protocol for a standard usb keyboard*/) {
//need to look at keyboard protocol
return(0/*WHATERVERINEEDTORETURN*/); //!!!!!!!!!!!!
Thanks!!
