Microcontroller task- controlling LED brightness using PWM and EEPROM
Discussion in 'Embedded Systems and Microcontrollers' started by GautamVK, Dec 5, 2010.
  1. GautamVK
    Dec 5, 2010
    10
    Hey there
    I am urgently looking for the codes for PIC16F628...
    Please forward the codes if you have or come across!
    Task:
    A switch controls the brightness of one LEDs, except for "OFF" mode.
    The equivalent value of 30 should be written on the EEPROM.
    Please forward the codes.. Thank you :)
  2. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Seems like the professor is giving you lots of homework lately. Or did you wait till the last minute to turn everything in? ;)
  3. t06afre
    May 11, 2009
    5,939
    1,222
    I would guess it is the last option. I think the honourable GautamVK has been coasting the whole semester. Maybe the focus has been on beer and girls:cool:. Now the semester is at the end. And the lab assignments are due:eek:. I used to bully some of the nerds to let me copy their works. Worked every time (just joking)
  4. retched
    Dec 5, 2009
    5,201
    313
    Actually, he IS the teacher.
    All the students turned in their assignments and he doesn't know if they are correct or not.
    He was just going to give everyone a "C" just in case. But after sleeping through the semester, he decided that the only 3 assignments. each worth 33% of the final grade, should be correct.
    Since he lost his "teachers edition" text, he needs someone to "re-write" the answers that were in there.
    They pulled him out of his role as"Classical Oboe Theory and Technique" substitute and put him into "Intro to PIC Micros". He doesn't know the difference between a right and left handed soldering iron.
  5. GautamVK
    Dec 5, 2010
    10
    :Dsomething like tat!! :mad:
  6. GautamVK
    Dec 5, 2010
    10
    yeap... when u push the button, the brightness should alter!
  7. GautamVK
    Dec 5, 2010
    10
    hahahha:D! come on u dont have to say ur joking!! its every1 sstory out there!!
  8. GautamVK
    Dec 5, 2010
    10
    owh come on! i am a student! even if i happened to be a lecturer i wouldn't be torturing the students no way in hell like this! its murder man! haha! i would rather cancel of the assignments!
  9. maxpower097
    Feb 20, 2009
    795
    388
    +1 to that...
