Microcontroller system on Ethernet
Discussion in 'Embedded Systems and Microcontrollers' started by 2rlp, Jun 26, 2008.
  1. 2rlp
    Feb 27, 2007
    7
    My superiors want me to design a Tea / Coffee vending machine with Ethernet capabilities. At present our vending machines stand alone, operator oriented and are controlled by an Atmel 89C52. Any ideas how I could go about designing this? Will Microchip's ENC28J60 & Atmel's 89C52 do the trick? I am not much aware of the Ethernet system :(
    Ron
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Whichever microcontroller you select should have the Ethernet capability built in for simplicity. And it will need to be able to handle the process control loop to dispense the coffee/tea, plus any other additional capabilities (like supplies inventory, cash on hand, state of the change dispenser, jams, etc.).
    If the Ethernet isn't possible as a feature, then some tranceiver board has to get put in, along with the added features in the program.
    Don't hurry - as soon as it's ready, somebody will insist it be changed to go wireless. Seen that happen.
  3. John Luciani
    Apr 3, 2007
    477
    The least expensive hardware cost would be to use uC with an ethernet interface.
    The quickest way would be to add an Ethernet module. Checkout the O'Reilly book
    "Making Things Talk" for some ideas on Ethernet modules.
    (* jcl *)
