Microcontroller selection
Discussion in 'Embedded Systems and Microcontrollers' started by nmanu06, Jan 28, 2012.
  1. nmanu06
    Jan 28, 2012
    9
    Can anyone please suggest me a low cost 8 bit microcontroller with the following features?
    1. Minimum 20 General Purpose I/O lines
    2. 3.3V supply.
    3. One Serial Channel.
    My goal is to set up a parallel interface for printer. This microcontroller is just to receive the parallel data through the centronics parallel connector and to send it serially to the main controller, which will do the further processing.
    Manu
  2. btroush
    Oct 28, 2011
    7
    Couldn't you just use a parallel in/serial out shift register?
    nmanu06 likes this.
  3. nmanu06
    Jan 28, 2012
    9
    It can not be done that simply.
    Parallel communication between printer and PC is accomplished with a number of control signals including Strobe, Busy, Ack, etc. Printer should respond to the signals from PC appropriately.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Almost any micro with enough IO would be up to such task. Do you have access to a programmer of some sort. Or do you plan to get one. As this will decide which brand of controller you can use
    nmanu06 likes this.
  5. MrChips
    Oct 2, 2009
    12,623
    3,451
    Why do you want to control a printer through a parallel interface? All printers today use a USB interface.
    nmanu06 likes this.
  6. PaulEE
    Member
    Dec 23, 2011
    423
    32
    nmanu06 likes this.
  7. spinnaker
    Oct 29, 2009
    5,062
    1,160
    nmanu06 likes this.
  8. nmanu06
    Jan 28, 2012
    9
    Hi friends,
    Thank you very much for helping me
    Manu.
