Microcontroller questions
Discussion in 'Embedded Systems and Microcontrollers' started by soniya, Jan 21, 2014.
  1. soniya
    Jul 24, 2013
    5
    Hello Sir/Mam ,
    Please tell me the reason that why clock frequency of 8051 is 11.059MHz why not 12MHz
  2. soniya
    Jul 24, 2013
    5
    please tell me where pic microcontroller is used & what r its features
  3. MrChips
    Oct 2, 2009
    12,636
    3,454
    I have moved your questions to a new thread here. Posting questions on someone else's thread is called hijacking and is not a polite thing to do.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    11.0592 MHz when divided by an integer(s) (1152 and 576) will produce a better approximation to standard baud rates of 9600 bits per second and 19,200 bits per second. A small sacrifice in execution speed increases the bit time accuracy of serial communications. This is a very common compromise.
    On ATmega processors from Atmel 7.3728 MHz is used in place of 8.000 MHz for the same reason.
  5. spinnaker
    Oct 29, 2009
    5,078
    1,180
    Which pic microcontroller? There are hundreds. Just go to microchip to view all of the various features.
    http://www.microchip.com/pagehandler/en-us/products/picmicrocontrollers
    They are used pretty much anywhere equipment is controlled electronically along with about of dozen or so manufactures that do the same thing.
  6. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
