Hi there!
So, i have only gone through a semester of a robotic class (using a microcontroller) was a BAD student (and i REALLY regret it since the class is no longer being held) Well, i currently have a invention on the lab table, and a microcontroller would wrap up everything nicely. the ISSUE is that my original plan will not work since a Arduino lillypad can only handle 5 volts, and there is a requirement of 3-4 RGB LED's for the full capabilitys to be released.
So, my questions:
1. (this is to clarify, im pretty sure this is a yes) a Microcontroller can be used to vary the "flow" of voltage. (changing the intensity of a LED light)
Is it posible to CODE a color, changing to a different color? to go more advanced, is it able to code down a "Timeline" to change back and fourth between colors (like coreography) and change between a fade, a strobe, and a flash. I BELIEVE this is all a yes, but, i would LOVE some in-depth explanation.
The IDEA is to use a microcontroller to change the flow of power (i believe its voltage) to change a RGB led to any color, and any intensity.
2. RGB LED's as i am aware, have all RED, GREEN, and BLUE in 1 LED. and can change the voltage as wanted between all 3, individually to create different colors. so my question is, do you measure each R,G,and B, as a seperate LED? or does it allways take the same voltage?
3. Since the idea of using a lillypad probably will not work, i need to find out how hard it is to build your own circuitboard. granted, the maximum size that i can have everything is a diameter of about 4 inches.
4. do you need resistors and other things in work with a microcontroller?
5. whats the highest electrical output for a microcontroller? (yes, i am aware you can go as high as you want with computing, but i need to find something that can do everything i need in the most compact capability)
gona go look on wikipedia more in a bit, but i find human correspondance is allways nice to throw ideas back and fourth, thus i ask these questions here.
Thanks for reading!!
So, my questions:
