microcontroller pwm to drive mosfet
mah
Joined Mar 15, 2010
393
is it possible for microcontroller pwm to drive mosfet however the mosfet needs 10 v to turn on while the output of the micro don't exceed 5 v
MaxHeadRoom
Joined Jul 18, 2013
28,699
There are 5v gate level Mosfets, for the simple low power switching such as relays etc, there is the 2N7000 FET darlington-equivalent designed for this purpose.
Max.
AfdhalAtiffTan
Joined Nov 20, 2010
120
MOSFET is a voltage controlled device, depending on the characteristic, at 5V, the mosfet could be saturated at lower drain current. Datasheet would be helpful.
