microcontroller programming in keil software
Discussion in 'Embedded Systems and Microcontrollers' started by soniya, Feb 5, 2014.
  1. soniya
    Jul 24, 2013
    5
    Hello sir/Mam ,
    As i am running the below program in keil μvision3 error 65 occurs with massage access violation at C:0x0028 :no 'execution / read' permission .
    The program is to copy the the 8-bit data stored in internal RAM location 27h to external memory location 30h.it does not show th 33h data into @R0 register.
    org 0000h
    ljmp start
    org 0020h
    start:mov 27h,#33h
    mov a,27h
    mov @r0,30h
    movx @r0,a
    end
    Please help to solve above program
  2. soniya
    Jul 24, 2013
    5
    as clock frequency of microcontroller 8051 is 12MHZ but we considering 11.059MHZ what is the logic behind this
    Please help me by answering this ?
  3. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    11.059Mhz is a good base for a UART divisor.... All baud rates with the smallest of error...
    For instance.. 9600baud on a 12Meg Xtal will give about 0.9% error where as 11.059Mhz doesn't... (Might be a bit more than 0.9%)
  4. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    To answer your code qusetion ( completely missed that )
    Code ( (Unknown Language)):
    1.
    2.    org 0000h
    3.    ljmp start
    4. org 0020h
    5. start:
    6.    mov 27h,#33h
    7.    mov a,27h
    8.    mov r0,#30h ; (Your Xternal data location is an actual number... Preseeded with '#'
    9.    movx @r0,a
    10. end
    11.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    In the original code fragment R0 is never initialized. Did you mean to write:
    mov r0,#30h
    to put the value 30h into R0 prior to using it as an indirect pointer in the movx instruction. In a real 8051 part you need to understand that the contents of port 2 (P2) will be output on the high order address lines [A15..A8] during the movx @r0,a instruction. The contents of R0 will appear on [AD7..AD0] and be latched by the falling edge of ALE*. Then [AD7..AD0] will switch to the content of the accumulator (ACC), and WR* will go low indicating a write operation. The data on [AD7..AD0] will be latched into the external device by the rising edge of WR* or WR* OR'ed with CE* depending on the device.
