microcontroller Programmer!!
Discussion in 'Embedded Systems and Microcontrollers' started by silvarblade, Jul 26, 2008.
  1. silvarblade
    Jul 23, 2008
    7
    i wanted to know if there was a programmer which is cheaper then the TOP2005+ or TOP2005 programmer (costing 80$) ad can program all pic chips and the usual old and unreliable 8051,8052. :p
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    A nice site about several microcontrollers is this one :
    <Link removed>
    There are also some programmers over there.
    Greetings,
    Bertus
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    I'm not aware of an "all-in-one" solution. My suggestion would be to look at using a dedicated kit and use the programmer specific to that device. Obviously that has the problem of locking you into a particular device/manufacturer.
    If you want to ease the device restrictions I may be able to suggest something more suitable.
    Dave
  4. silvarblade
    Jul 23, 2008
    7
    well i need to use the 16f84 and some of the 18f series of pics and if it doesnt program other chips than its k. any ideas?
  5. silvarblade
    Jul 23, 2008
    7
    i found this schematic on a website. should i construct it?and the 16f84 is not listed in the supported ic's.
    ARE THE PIC CHIPS NOT REPROGRAMMABLE!! THAT IS EEPROM??HOW ABOUT THE 16F84?
  6. silvarblade
    Jul 23, 2008
    7
  7. silvarblade
    Jul 23, 2008
    7
    i found this schematic from the website of winpic800 it is said that it can program neary all pics and some avrs. will it work and what about the code for the 18f2550 which i assume will be main piece of programming firmware.i can get it programmed if i find the code.also is a junebug clone better than a clone of this programmer??
  8. Bobdog
    Aug 13, 2008
    Picked up a virus at this suggested web site. My virus checker took care of it, but be on the alert! <Link removed>
  9. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Some scanners are picking something up, so to be on the safe-side I have removed the link.
    Dave
  10. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
