microcontroller program memory
Discussion in 'Embedded Systems and Microcontrollers' started by mik3, May 2, 2008.
  1. mik3
    Thread Starter Senior Member
    Feb 4, 2008
    4,846
    63
    hi guys,
    I want to buy a microcontroller programmer. I have started with PIC so i prefer one for PIC's but a universal would better i think. What is your opinion?
    Do you know a good and cheap one?
    Also i want to ask which microcontrollers have the more memory to store the program, PIC's or AVR.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    ATMEL recently introduced the AVR 8-bit XMEGA series. It has 256Kbyte of Flash memory for program storage.
    The only downside is that the development board, the STK600, has only recently become available and so it is a bit pricey at the present time.
    hgmjr
  3. Reshma
    Mar 11, 2007
    54
    Here is a Universal Device Programmer, I came across.
    http://www.hed-software.com/hedchip.htm
    PIC/Atmel serial programmers are more cheaper of course. ;)
  4. chrischristian
    Feb 22, 2008
    43
    I don't know that you are an expert or not but, if you want to start learning microcontroller programming than I think PIC KIT2 would be grate, as far as the universal progarmmer is concerned I don't think that it is a very resonable choice for a hobbiest so, if you are not someone who required to make one new project every week or so OR you have plenty of money to sped on your hobby I advice you to not to go for universal programmer. If you are just a hobbiest than just one or two PICs would be enough for almost all your projects so don't worry about memory and all that things, I am reffering you to PICs because they are lot easy to learn ( at leat that was so with me!). Here are some helpful links:
    http://www.mstracey.btinternet.co.uk/pictutorial/picmain.htm
    http://www.winpicprog.co.uk/pic_tutorial.htm
    Hope will be helpful!
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Mik, check the thread on PICs Vs AVRs you may find some useful information: http://forum.allaboutcircuits.com/showthread.php?t=2601
    As for an appropriate PIC, have a look at the 18xxx series. It is one of the higher end PICs but you will not find yourself restricted in many uC applications. You can then get the MPLAB and the C18 compiler from over Microchips website and develop your programs in ASM or C depending on requirements.
    Dave
