Microcontroller light dimmer - amplifying light bulb
Discussion in 'Homework Help' started by markodaguy, Dec 5, 2015.
  1. markodaguy
    Mar 24, 2015
    9
    Hey,
    I need some help with a school project. I'm building a light dimmer circuit with the use of microcontrollers; specifically using the PIC 18M2 to control the dimming of the light bulb. With 18M2, I am using a pwm code which can vary the voltage depending on a readadc input voltage. The code works perfectly but I would like to use a 7V filament bulb (so I can vary the voltage from 1-7V) as the output however the maximum voltage rating of the 18M2 is 4.5V. I was thinking about using a MOSFET to amplify this voltage but I'm not sure on how to do it. Does anyone know of anyway that this could be completed?
  2. Dodgydave
    Jun 22, 2012
    5,172
    778
    are you doing a DC PWM with a mosfet to control the bulb?
  3. GopherT
    Nov 23, 2012
    6,340
    4,094
    You need a mosfet that will switch at "logic level", several amps of current handling capability and low gate capacitance.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    likely bolted to a heatsink.
  5. GopherT
    Nov 23, 2012
    6,340
    4,094
    I've been using these lately. They laugh at 1 or 2 amps. SMDs with 15 mohms on resistance. No heat sink needed with reasonable switching speeds and Pwm frequency.
    http://www.vishay.com/docs/66587/si4666dy.pdf
    MikeML likes this.
  6. markodaguy
    Mar 24, 2015
    9
    Yeah, that's what I'd like to achieve lol
  7. markodaguy
    Mar 24, 2015
    9
    Thanks, do you have examples of such mosfets?
  8. Dodgydave
    Jun 22, 2012
    5,172
    778
    Irf640, mosfet, will do the job, there are others too..
  9. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,529
    You would need the logic version, IRL640.;)
    Max.
  10. GopherT
    Nov 23, 2012
    6,340
    4,094
    S
    See post 5 if you are able to make a board and solder surface mount components.
    Otherwise, use the irl640 that max suggested in post 9
