can some one tell me how the microcontroller can control the power mosfet as a switching
C Thread Starter cpleng7 Joined Dec 18, 2008 120 Sep 19, 2010 #1 can some one tell me how the microcontroller can control the power mosfet as a switching
L lihle Joined Apr 12, 2009 83 Sep 19, 2010 #2 cpleng7 said: can some one tell me how the microcontroller can control the power mosfet as a switching Click to expand... its simple just Google the staff. what you can do is to set up the pin high that would activate the gate.
C Thread Starter cpleng7 Joined Dec 18, 2008 120 Sep 19, 2010 #3 since the gate of the mosfet is receive the current pulse , how the microncontroller send the current pulse? second question is that power mosfet can act as a SPDT switch? how the schematic look like?
E electrontube Joined Sep 19, 2010 3 Sep 19, 2010 #4 just use a transistor ,there is nothing to it at all, any npn u can find, or general purpose.
retched Joined Dec 5, 2009 5,207 Sep 19, 2010 #5 You can use a LOGIC LEVEL MOSFET. This will accept standard logic levels on the gate. They work quite well with micros.
C Thread Starter cpleng7 Joined Dec 18, 2008 120 Sep 19, 2010 #6 but if using the transistor, the switching speed is lower than the switching speed of power mosfet. how to solve the problem? Is that the transistor can works as a SDPT switch
retched Joined Dec 5, 2009 5,207 Sep 19, 2010 #7 A Single Double Pole Throw switch? How fast switching do you need? FETS are pretty fast these days, and unless you have a 20+MHz microcontroller, you should be able to switch a MOSFET just fine. Have a read here for high speed MOSFET driving drivers http://www.analog.com/en/press-release/11_19_09_MOSFET_Drivers_Improve_Efficiency/press.html
