Microcontroller Based Signal Generator
Discussion in 'Homework Help' started by chamara, Jan 31, 2012.
  1. chamara
    Oct 22, 2011
    21
    Requirements
    >Resolution:Maximum 20mV
    >Range:--2.5Vto +2.5(should be adjustable 2 buttons-up/down)
    >Frequency Range:0 to 10 kHz (should be adjustable 2 buttons-up/down)
    >Waveforms:square/sinusoidal/Traingular(should be selected using toggling 1 button)
    >When the systen is powered on,the frequency,level and waveform shape used on the last use should be used as the default values
    Can u tell me which PIC is good for make this Signal Generator?
  2. chamara
    Oct 22, 2011
    21
    Plzzz help me..............
  3. lightingman
    Apr 19, 2007
    374
    22
    You could use a PIC micro and an AD9833.
    The required frequency, waveform and level can be sent to the AD9833 over the three wire interface. They are quite easy to use, but you really must read the date sheet very well.
    Daniel.
    chamara likes this.
  4. chamara
    Oct 22, 2011
    21
    Can u tell me a PIC number,that suitable for this project?
  5. atferrari
    Jan 6, 2004
    2,663
    783
    He is trying to control output levels. How would you do that with the PIC and with the AD9833?
    chamara likes this.
